Diode Token
The Diode Token, the “DIODE”, is a utility token that is used by the Diode Network to enable communications and other network activity. You can view the DIODE token on the Diode L1 explorer and also as bridged to Moonbeam.
See the Diode Foundation whitepaper for more information.
